joelyn
Feb 24, 2014Explorer
2012 ram 1500 short bed?
have a 2012 ram 1500 2wd crew cab and found a small 5th wheel 21 ft with a dry weight of 4040lbs and a GVWR of 5756 LBS. should my 1/2 ton ram be able to handle this?
thanks
thanks
thanks
Eng208 wrote:
What powertrain? Look at the door jamb. On my 2013, they took the guess work out of the payload and it is clearly stamped on there. Mine says 1923lbs I think. that includes everything not factory, people, gear, and trailer. That is a very light fifth wheel and you should be fine weight wise. Do you have a 6.4 ft bed? I would think that would be minimum to keep you safe from hitting the cab.
