dzirkelb wrote:
I am going to get a new Ford, 3/4 ton or ton, but not quite sure which one. It looks like the ton truck allows me to get more fifth wheel towing capacity, but I have to change the axel ratio, which in turn will give me some crappy gas mileage.
But, it looks like the ton / 3/4 ton on the 3.73 has the same towing capacaties, is that right? If so, what's the benefit of a 2013 ton Ford GAS over a 3/4 ton with the 3.73 axle ratio?
What are all the boys with the 1 tons going to think when you pull in with a 3/4 ton and then not a diesel. They will never talk to you again.
