dzirkelb wrote:
I see the max payload increase now, but how do I read the chart?
http://www.ford.com/trucks/superduty/specifications/payload/
I know I'd be getting a F-350 SRW 4x4 if I went ton truck, but how do I know what the paylod is as there are so many options on teh GVWR (lbs) column? I'd get a crew cab also.
And, what is the gas mileage difference between the 3/4 ton adn the ton gas with same specs?
The truck in my sig is a fully loaded, king ranch, crew cab, 4x4.
Payload -- 3493# per the door sticker. Just to give you an idea.
You would not notice any difference in mpg's from a 250 / 350, as they are the same engine, same gearing, (assuming it is), really the same truck, just a little heavier which really will not effect mpg at all.
