nohurry
Apr 23, 2016Explorer
Gdetrailer wrote:nohurry wrote:
My '15 does indeed have low, med, and high settings. I previously owned a '13 F250 with the gas motor, and had the same issue, which is probably why they changed it. I have heard that the dealer can increase it, and that is your only (Factory), option. Worth a try. Good luck.
I have a 2013 F250, it DOES NOT HAVE "low, med, high" settings..
It also DOES NOT HAVE ANY ISSUE WITH "WEAK BRAKES".
Now to be kind of "fair" I will also mention that I HAVE UPGRADED the wiring on my trailers from factory 14Ga to dual pairs of 10 Ga wire, BEFORE I bought the 2013.
I have no problem with not enough brakes and that is with using a 4.5 setting on the IBC.
Before you start blaming the IBC I would recommend that you UPGRADE the wimpy factory trailer wiring which is either 14Ga or possibly 12Ga which is allowing TOO much voltage loss by the time it gets to the brakes.
Good point, and definitely worth trying first.
44,068 PostsLatest Activity: Jun 17, 2026
