Gdetrailer
Apr 27, 2016Explorer III
BenK wrote:
Knew most of that and mainly why I don't like 'Highly Integrated'
anything or most anything on my vehicles
Akin to the all in one FAX/Printer/Copier/FAX machines. If one goes,
the rest of them goes too.
After a few, now have individual machines for each function.
Yes, know enough about systems and computers to understand all that
When Ford first introduced a IBC it did indeed have a lot of complaints and there was problems..
Most problems however where the fault of the trailer wiring.
Fords first version of a IBC was overly sensitive on detection of the trailer.. This showed just how cheap and badly wired the trailer manufacturers allowed to pass out their doors.
The "fix" was to rewire the trailer PROPERLY using better connection methods than the trailer manufacturer used..
I personally intentionally did not order a IBC on our 2006 F250 due to my suspicions about having an IBC.. I had visions of dragging my trailer back and forth to the dealer.. So, I bought a second Jordan Ultima 2020 at that time.
Fast forward to our 2013 F250, IBC comes standard.. Had no choice..
The first tow resulted in no errors, no disconnects, no problems..
Works as smooth as my Jordan 2020s in my 2003 and 2006 F250s!
So far, logged about 8,000 miles with the 2013 IBC and still works as well as my old faithful Jordans.
There are just too many Ford trucks out there with IBCs to say they are junk.. One must understand that IBCs WILL SHOW ANY DEFECTS IN YOUR TRAILERS BRAKES OR TRAILER WIRING..
Heed my advice folks, weak brakes are most likely due to problems on the trailer side, not the controller.. You NEED to do some troubleshooting of your trailer BEFORE condemning the IBC or dragging the vehicle to the dealer.. Doing so will eliminate a lot of back and forth with the dealer when they tell you NPF (No Problem Found).
Yes, you could bypass the IBC and perhaps use a Prodigy and get some additional braking form the way it works, but you are not FIXING the real problem. You are simply masking or putting a temporary bandaid on the problem.
Start troubleshooting by removing the controller from the mix..
Hitch up, don't connect the trailer cord to the vehicle.
PULL the breakaway pin.
Pull forward.
The trailer brakes MUST LOCK UP and SLIDE the tires.
IF the tires do not slide, the problems are on the TRAILER SIDE.
IF the tires DO SLIDE, then the problem is most likely on the VEHICLE SIDE.. This is when you take it to the dealer.
To trouble shoot the trailer side you can use an ammeter at the trailer battery and pull the breakaway pin.
two axles should draw about 12A (3A for each wheel magnet) with a fully charged battery..
If you read LESS than 12A then you have a WIRING ISSUE.
If you read 12A then you have a MECHANICAL ISSUE..
If you don't have a ammeter, then you can take a voltage reading at the battery with the pin pulled.. Write that voltage down.
Then at each wheel check the voltage at the magnet connection.
Each magnet should have almost the same exact voltage and there should not be much voltage drop.. I would suggest that if you see more than .1V drop from battery to any magnets you have a wiring issue.
For mechanical issues you can look up lots of great info on axles through Dexter axles website. They should have all the procedures on properly adjusting the shoes.
Additionally, if you find grease on the shoes you will need to clean the grease off or replace the affected shoes.. Just remember, if you change shoes, you MUST change the other side on the same axle.. Otherwise you risk having the trailer pull you to the left or right..
44,068 PostsLatest Activity: Apr 17, 2021
