ScottG
May 05, 2014Nomad
usmcshepherd wrote:
I have full truck lights and all lights on camper work except right rear turn signal and backup light. All connections that I can access are cleaned and tightened, but still no luck. If thisTIMP circuit is tripped would that shutdown the entire camper or just one light? Also, the right side marker light works as do the loading lights which are all part of the rear harness. I think I'm at the point of checking the current and at this point I don't have anything to check that. Any other suggestions are welcomed and appreciated!
The TIPM will shut down individual circuits. So it can shut down just one turn signal and back-up lights on the trailer connector without affecting any lights on the truck itself.
You need to get a volt meter and check for voltage where the camper plugs into the truck to isolate the issue. If you get a very low or no voltage on that connection then the truck is the culprit. But the TIPM only shuts off power if there is a real short - so you have to fix that as well or it will just happen again after the reset.
44,061 PostsLatest Activity: Apr 09, 2026
