davejodoin
May 09, 2014Explorer
you will find the fuse panel hiding under your step to the bed, behind the electrical box, probably mounted on the bottom of the back piece of plywood under the slide out relay module, i had to move mine so it was accessible.I ended up moving the slide out relay module to the right and moving the taillight fuse panel (which has a clear plastic cover over the fuses) betweem that and the isolator
44,061 PostsLatest Activity: Apr 08, 2026
