SweetLou
Jul 05, 2021Explorer
cummins2014 wrote:Cummins12V98 wrote:I went originally to parts counter there when I suspected the actuator. His quote was 3600. Obviously wrongSweetLou wrote:Cummins12V98 wrote:
Lou your money but I would not change out the turbo if actuator is bad.
Part of the problem is Geno's and City diesel are out of stock, so may be forced to get the turbo as well. Geno's says until 7/16 but what if I wait and they extend that as well? I can't get a mechanic so far to start work until 7/20 and I do need to truck. I'll wait for the dealer and the codes they found first
Too bad you are not on the West side of WA. My Mechanic friend recently installed the City Diesel actuator on a 13 and it was a piece of cake. He also had to wait and ordered directly from City. The truck was fine to drive around until the part arrived. My truck was fine to drive also, the EB was intermittent.
I’m wondering why your actuator, was over 1k more then what seems to be a reasonable cost from other dealers . Only reason I bring it up is to let members know if they go with a dealer , the cost should be $2200 . Any reason why yours was that much more ? Regardless whether you had warranty or not should be a standard charge from a reputable dealer .
