SweetLou wrote:
Here's another question; if the actuator does not go out abruptly, can it reduce your MPG? I towed 2K coming from south to the north and noticed no performance change, plenty of power, but mpg much lower. Also, had intermittent clattering of the engine. Cold engine, no issues or sounds. Electrical issues I have with the truck will probably end up being the BCM once again but it had something to do with TH not being able to be engaged as well as the EB. They would come on 20 min or so down the road. No electrical communication to actuator could cause issue right?
Not a vvt expert here, but I’ll say yes it’s possible. Do you have a boost gauge and is/was boost the same as before?
So dealer diagnosed it definitively as the actuator it sounds like?
Still unclear if truck is in limp mode or what, but there are a lot of private diesel shops in the Spokane/CDA area, however I’m sorry, I don’t have a recommendation.
Good luck finding an actuator….I can’t even get a new hub for a bicycle wheel currently.
