If you can't store your trailer on your property or keep it there for at least 24 hours, avoid a hybrid unless it is one that has a hard sided slide out bunk. We had popup campers, and quite often, they had to be opened up and allowed to dry after returning home.
The question I would ask is what is your towing weight limit? If you can answer that, you may get suggestions on lighter travel trailers that have more space or a better layout than the Starcraft. That being said, Starcraft makes a very decent trailer, but look at others by Jayco and other reputable companies.
