jmtandem
Aug 15, 2014Explorer II
I was under the impression that the Aisin is not a better transmission (nor worse) but rather for two different applications. The Aisin has a PTO port for use on a dump bed etc. The 68RFE does not. This is why the Aisin is typically used on the cab/chassis trucks and the 68RFE on the 2500/3500's. I see the Aisin is now an option on the 3500's but if no need for the PTO port I would think the 68RFE is every bit as good. My 2007 Ram has the 68RFE and zero problems and truck is used 80% of the time for towing.
With the Aisin the Cummins will put out 850 ft/lbs of torque. With the 68RE the torque is slightly less. There mst be other differences other than PTO.
