AH64ID
Aug 15, 2014Explorer
SRW vs DRW is always a debate. Yes there is more stability when comparing apples to apples. 4 LRE tires are more stable than 2, and it's not just the width (really little with the width IMHO) it's the stifness. If the outers where the same width as the SRW and you could keep the springs in the same spot the DRW would still be more stable.
Both the SRW and DRW pivot the suspension at the same point, so any sway reduction or stability improvement on a DRW is from a lack of tire deflection.
Super single, for a pickup they are the 19.5" conversions. While it's probably not quite as stable as a DRW I am willing to bet that for most loads it is. LRG sidewalls are much stiffer than LRE, and designed differently.. but somehow they really don't ride any worse on a 1 ton.
So 2 tires at 110psi to carry 9,000lbs or 4 tires at 65 psi to carry 9,350 lbs (limits on SRW (245/70R19.5) and DRW applications for same truck, i.e. 03-12 Dodge). Probably about the same.
Stock for stock a DRW will walk all over a SRW, but if a DRW isn't an option it's not difficult to make a SRW compete in all aspects with a DRW.. and it still is easy to drive on tight back roads.
The pickup Aisin is a different Aisin than the 07-12 C&C Aisin.
As 12V said, they don't break.. where the 68RFE will work for most people.
The Aisin design, gears/clutches/etc, is designed more towards heavy duty use. Not that the 68RFE is weak, just different.
mileshuff wrote:
I was under the impression that the Aisin is not a better transmission (nor worse) but rather for two different applications. The Aisin has a PTO port for use on a dump bed etc. The 68RFE does not. This is why the Aisin is typically used on the cab/chassis trucks and the 68RFE on the 2500/3500's. I see the Aisin is now an option on the 3500's but if no need for the PTO port I would think the 68RFE is every bit as good. My 2007 Ram has the 68RFE and zero problems and truck is used 80% of the time for towing.
