brholt
Aug 19, 2014Explorer II
AH64ID wrote:brholt wrote:
All other things being equal this is probably accurate. However, in late model trucks, at least Ford, you also get different components such as better brakes and a stronger rear axle.
Ford advertises the same brakes on all pickups, F-250 thru F-450.
Same rotor Diameter (14.29).
However, rear brakes on DRW (F350 and F450) get bigger piston calipers (2.13 instead of 1.89) and get hydro boost instead of Vacuum.
See page 83 here:
2013 SuperDuty specs
2014 and 2015's are the same except for the F450 with the 19.5 wheels.
