LarryJM
Jun 02, 2014Explorer II
Lowsuv wrote:
Kumho 857
size 205R 14
placarded 2271 # on an LT rating scale
available from tire rack
order on Monday , delivered to your tire installer on Wednesday , installed on your trailer Thursday .
I've got 'em on my boat trailer .
gmwphotos has 'em on his tt .
they weigh about 3-5 pounds more than the ST tires of the same size .
speed rating is 106 mph .
st tires are 65 mph .
in a 14 inch size this particular tire is the very clear choice .
I've had the Kumho 857 in the 195R14C (2094lbs @ 65psi) which is almost an exact size replacement for the normal ST205R75x14 tire for a year now and have put close to 6K miles on them and am pleased with them so far and would recommend others to give these tires a shot. You will probably need new rims since almost all 14" rims are only rated for 50psi. In addition to a much higher speed rating the extra load capacity over a similiar ST tire is an important fact to consider.
Larry
