- ib516Explorer II
ShinerBock wrote:
0-60 Times:
Ford F350 440hp/860lb-ft 3.73 DRW - 8.17 sec
RAM 2500 370hp/800lb-ft 3.42 SRW - 8.9 sec
So 70hp/60tq and steeper gears buys you 0.73 of a second. Impressive powertrain, and I mean that. The 6.7L is strong.
Now if Ford would just update the cheap hard plastic interior by rubbermaid, and the twisty 1999 frame. - Road_RunnersExplorerGee, who cares what the 0 to 60 mph times are. Trucks are designed and used for hauling and towing not drag racing.
- Garry_GayleExplorerThat's whats wrong with the way diesels are being used, they are for torque not drag racing. I just want to know how well it pulls 20K of trailer
- The_Mad_NorskyExplorerNever started my 2011 in the fashion they did in the video.
RE: 1600 RPMS on brakes then let her fly.
But it was also very quick to get up and fly. It would set up to mid 80's or 90 MPH if needed and do so very quickly.
My Ram now does about the same. Time wise one versus the other I have no idea, but they surely feel similar and both get/got me up into mid 80's on hard acceleration real quick. - TXicemanExplorer IIWho really cares. What really matters is how well it will tow at max GCWR,
Ken - RobertRyanExplorer
estesbubba wrote:
When I'm towing it's all about the 0-60 times. I like to hit every exit ramp on the interstate so I can try and beat my last time. Just because your truck will tow 10 hours in overdrive doesn't mean it doesn't suck.
Scratching my head on that as well, strong means how much it carries and tows in a reasonable time - mtofell1ExplorerSo, the Hemi 6.4 has been out for a little over year and you finally found something the Ford has on it. And relevant to towing too I might add. I guess I'll reconsider the next time I'm drag racing an F350. Thanks for the heads up.
- estesbubbaExplorerWhen I'm towing it's all about the 0-60 times. I like to hit every exit ramp on the interstate so I can try and beat my last time. Just because your truck will tow 10 hours in overdrive doesn't mean it doesn't suck.
- Turtle_n_PeepsExplorer
FishOnOne wrote:
Turtle n Peeps wrote:
agesilaus wrote:
There is a video showing a stock F350 6.7L doing 183 mph on the Bonneville flats, it's on youtube somewhere
The math just does not work out on that.
I think it had a aftermarket turbo and a tuner.
Ya, the 32 Chevy I drive that turns a mid 9 in the 1/4 is all stock................... well except the 572 engine, the tranny and the rear end. :B But other than that, it's all stock! :W Turtle n Peeps wrote:
44,045 PostsLatest Activity: Aug 01, 2025
