dean271 wrote:
Jeremiah,
These are the vehicle spec's - Got 3.5 Eco-boost, payload 1628, axle code L9? Front GAWR 3450 lbs., Rear GAWR 3800 lbs., GVWR 7000 lbs.,GCWR 16,900, Base Curb Weight (No cargo/passengers) 4925 lbs....
We haven't purchased an RV yet, don't want to make a mistake. We do want a toy hauler.
Chart is hard to read but you have a 3.55, Electronic Locking rear.
Use this chart to
find the axle ratio that corresponds to that code:
Rear Axle Non-Limited Limited Electronic
Vehicle Ratio Slip Slip Locking
F-150 3.15 15 Not Available L5
3.31 27 Not Available L3
3.55 19 H9 L9
3.73 26 B6 L6
4.10 Not Available Not Available L4
Also have another quest. IF you have a actual curb weight of 4925lbs, and you have a GVWR of 7000lbs. Would you not have a actual payload of 2075lb, as GVWR minus curb weight equals payload. Or GVWR of 7000lb minus truck weight of 4825lb equals carrying capacity of 2075lbs. ?
What am I missing.
