firemedic85
Oct 23, 2014Explorer
Lots of difference between the two from ground up. The ORV much heavier with Buffy frame 15 inch wheels shock absorbers. Lance is more 1/2 ton towable. Fresh water capacity will be huge factor if you dry camp a lot. ORV built by same company as Arctic Fox Northwood MFG.
Lance great trailer but like I said ones half ton towable and the other is borderline. I personally would check out the Arctic Fox line and the Snowriver line on the northwoodmfg website if towing is not an issue.
