Cummins12V98
Mar 11, 2015Explorer III
The Mad Norsky wrote:
I changed oil at about 3,200 miles on my new Ram.
First, I am NOT gonna run factory oil for 15,000 miles in a brand new engine.
Second, I, and I don't think anyone else around, really knew what kind of oil was in the motor anyway. Some said 15W/40 Rotella, others told me 5W/40 Rotella and still elsewhere I was told 5W40 or 15W/40 Valvoline Premium Blue.
One could not even add a quart, if needed, with any degree of confidence that I was actually adding what was in the engine.
So now I DO know what is in the engine. And, if needed, could actually add a quart if low. Although this appears very low odds to happen, as the vehicle has used very little oil to date.
Mind you, next change will be higher mileage for sure. Still not wild about going 15,000 miles but we will see how things go. 7,500 miles or so was about the normal change on my last vehicle, and that may be where I go with this one.
Factory fill is 5-40 synthetic. I will only run my oil for a few thousand as you did.
I will be running AMZ/OIL 100% synthetic 15-40 and FleetGuard Stratapore filter. At the end of my second oil change I will do an oil analysis to see how the oil and engine are doing. Then decide if I want to go the full 15K if the truck says to go that long.
