Cummins12V98
Oct 01, 2016Explorer III
Grit dog wrote:
Running 70+psi in The front tires without additional weigh that require it is crazy IMO. Unless you just take out your false teeth so they don't rattle out!
Btw, not hard to get high miles out of bfg rugged terrains. They gotta be the hardest compound worst wet/snow/sand/anything but dry pavement tires ive ever run.
Perfect for pounding pavement cross country with heavy loads.....in good weather.
You may want to look at your actual front tire weights and compare to the weight/inflation chart. Then add 5psi for the fact the tires will have edge wear. Done this for hundreds of thousands of miles with great results and no MISSING TEETH!
