mhsmith
Aug 11, 2020Explorer
Chirping on take off usually indicates a u-joint going out. Carrier bearing will often make a roaring sound similar to newer hub bearings. Strongly advise not to go with single driveshaft. It will need to be heavierand even if it is built properly...the extra length will cause the shaft to want to spin kinda like a jump rope and cause another set of problems. If you have a lot of miles on the truck...may be a good idea to have the other u-joints and the carrier bearing replaced at the same time.
44,066 PostsLatest Activity: Apr 15, 2026
