otrfun wrote:
Me Again wrote:
Ron3rd wrote:
IdaD wrote:
Cummins12V98 wrote:
IdaD wrote:
I use 5w-40 Rotella T6 synthetic because it's required in my area due to winter temps, though I run it year round and plan to do so going forward. It runs about $18/gallon on Amazon subscribe and save. I also use the Stratopore fleeguard filter.
As far as changing the filter, I got the filter end wrench from Geno's that attaches to a ratchet and it works well. Once I get the filter loose I drop it into a freezer bag, seal it up and pull it through the hole. Then slide the new one through the hole, spin it on and good to go. It's not the most convenient location but it adds very little to the time or difficulty of the job.
Do you pre fill as Cummins suggests?
Nope, never have. It's never caused any problems with any vehicle I've been around and I was actually taught early-on not to pre-fill due to the potential of adding contaminants on the back side of the filter. I did do some research on it after I bought this truck and found nothing that convinced me it was a good idea - if anything I found more that recommended not doing it. Truthfully I don't see it as a significant deal either way.
Good point, and on another topic, Dodge instructs NOT TO PREFILL your fuel filters when replacing.
1. What does RAM say?
2. What does Cummins say?
Couple more questions:
1. If the oil filter is not pre-filled on a Cummins 6.7, how long does it take for the oil pressure to normalize?
2. How long can a Cummins 6.7 run with little to no oil pressure without sustaining any damage?
I can only speak to mine but my pressure comes up just as normal after a filter change as it always does. The oil pumps in these engines are big and to fill a quart filter is nothing. I also found out the dealer I bought it from does not prefill the filter either. And when I change mine I drop in a gallon ziplock bag and come out the wheel well with no problem. The only beef I have with Cummins is the 6 month oil change time frame. Mine is due now on time with only 600 miles on the oil. Until the warranty runs out I guess I will just do it but it is such a waste. Truck stays indoors climate controlled so how does the oil go bad in 6 months?
