S_and_S_Peaches's avatar
Mar 24, 2019
2016 F-450 TC Prep?
I have a 2016 F-450 crew cab that were going to use to carry a 2019 Northern lite 10-2 with. Is there anyone else with a similar truck and camper set up that might advise some prior truck prep before picking up our camper last of April first of May? Our camper is being built in April.
I'm adding Stableloads, and a SuperHitch Magnum with a 36" extension. I plan on pulling either a two horse trailer or a 16 ft. Fiberglass Trihull boat. I'm wondering if anyone with my setup had any clearance issues between truck cab and camper. Should I consider a bed mat addition to lift the camper up a little? All advice considered.
Thanks in advance.
  • Get a 7pin RV outlet installed in the front drivers side of the bed.
    Enjoy.
    - Mark0.
  • I doubt there will be issues clearing with a new camper, but I’d ask Northern Lite and ask for the recommendations on what to raise the camper if anything. Otherwise, it sounds like you have what you need. Personally, I’d prefer air bags, so I can adjust the height with different weight loads.
