invstr55
May 15, 2015Explorer
2016 Ford F350
Does anyone have any insight into the 2016 Ford F350? I have not been able to find a 2015 that we are happy with so am about to order a 2016 and have heard rumors about what the changes will be...any ...
Cummins12V98 wrote:invstr55 wrote:45Ricochet wrote:
Think the 2017 MY is the big change MY. Most likely few changes in the 2016. I'm pretty sure 2017 will have aluminum as does the new F150's. I can tell you though, a 2015 Ram is much different than your 2012 MY. Just saying.....
thanks 45, my 2012 had trouble with my old TH which was about 21k and the new one is 24k. It is fine on the flats but going up long grades was not much fun in the rockies.
What gear ratio is the 12?
For a heavy of RV as you have the RAM with the factory puck system and a B&W hitch will give you 25K towing and 6,250# pin weight. The new RAM's are SAE J2807 rated at a combined 37,900#
Your pin weight will require bags so why not have something that will set level up to max rear axle rating all by it's self?
Here is a pic of my RAM with 5,440# front axle and 9,360# on rear.
