- totoExplorerI had a 2004 Dodge Cummins with a 48RE.
If you left it in tow/haul it would stay in 3rd.
Check your tow;haul button and your owners manual.
It may be some thing simple.
Good luck. Perrysburg Dodgeboy wrote:
The 68RFE is no different than the Ford or GM transmissions when you add a tuner box to the truck. They all will fail if pushed past there intended limits.
True... but some just have higher intended limits than others.- cummins2014Explorer
nevadanick wrote:
Happened to me a couple days ago. Happened to a freinds truck. The dealer had the part there to fix another one and used it on mine because we were from out of town. Anyone else ? Seems common. Solenoid pack was the problem.
No problem here, but just run it in fourth, just a few more RPM's :B - blofgrenExplorerNo, mine doesn't stick in 4th gear at all...... ;) :B
- Perrysburg_DodgExplorerThe 68RFE is no different than the Ford or GM transmissions when you add a tuner box to the truck. They all will fail if pushed past there intended limits.
That is the number one reason GM couldn't add anymore HP/TQ to their trucks, the Ally they use (Allison 1000) was at it's limit. They fixed that for the 2017 MY though.
Don - 996PilotExplorer
Me Again wrote:
FishOnOne wrote:
donn0128 wrote:
Never heard of that before? The 68RFE has been extremely reliable with narry a complaint.
I would say extremely reliable is a bit of a stretch for the 68. My cousin makes a good living because of them.
OP,
I would go to the cumminsforum and ask in the 4th gen powertrain forum. There's a guy that goes by "trans engineer" that's really good. I'm certain he can answer your question.
And I would bet that 90%+ did not have a stock engine in front of the 68RFE!
+2 on that - nevadanickExplorerThe night it happened i googled it and it came up before i even finished typing it in so i know i'm not the first. Its dsl with 68rfe
- Me_AgainExplorer III
OP,
And I would bet that 90%+ did not have a stock engine in front of the 68RFE! donn0128 wrote:
OP,
I would go to the cumminsforum and ask in the 4th gen powertrain forum. There's a guy that goes by "trans engineer" that's really good. I'm certain he can answer your question.- mtofell1ExplorerIs it a diesel with 68rfe or gas with 66rfe?
I've also never heard of this that I can remember. I think you may have been struck twice by lightening :)
44,066 PostsLatest Activity: Mar 14, 2015
