ivbinconned's avatar
ivbinconned
Explorer II
Sep 10, 2017
2016 Ram 3500 auxiliary fuel tank plumbing??
I have traded off my 06 Ram cummins for a 2016.
I have a tank in box with filtered line to main tank. I can leave the valve open and fill both tanks and there has been no leaking.
Can I do same with this 2016??
  • ivbinconned wrote:
    How did you cut into metal filler tube and prevent filings from getting into tank.
    My installer pushed a rag down below where he cut and then pulled it out to catch any shavings.
  • Well now on my second time with a head of fuel in auxiliary tank I have a leak.
    First time it didn't.
    I just pulled off the wheel and wheel well so as to ascertain where it's running from. It's leaking right from the top where that green plastic is.
    It's as if the second flapper is not sealing and so it fills into the top wider compartment. The first flapper most be stopping it from coming out of the fill cap or else my dust cap is sealing it. Didn't pull it off.
    The only place it's leaking from is high inside of the fender. So ??
