towpro
Jan 12, 2018Explorer
uneven tire wear front to rear can also cause this. Rotate, Rotate, Rotate so all tires always have the same circumference. I see you have a dually so its kind of hard to do a real rotation because the rear inner wheels use a different TPMS frequency than the other 4 tires.
I will swap LF and RR outer, and RF and LR outer. inner stay where they are. This keeps tires rotating the same directions. only problem is one summer I have raised white letters, next I have black walls.
44,071 PostsLatest Activity: Aug 16, 2026
