covered_wagon
Jan 13, 2018Explorer
Ramp Digger wrote:towpro wrote:Now that I think about it I had a 1986 F-250 4x4 that had a 3.55 rear axle ratio and a 3.54 in the front. It was that way from the factory as I bought it new.covered wagon wrote:
Binding has happened to me on every 4wd that I've owned. It normal till you drive back or forth to unbind. Binding happens because the front is designed to spin a little fast than the rear differential. This affords better control in icy conditions and are all supposed to be this way.
I think you will find exactly the same ratio front and rear in any modern 4x4 truck.
But I have seen an old electric company pole truck with different ratio in front so it could steer in mud
That is a good truck back then. I think they might do the faster front spin with the transfer case now a days, but I'd have to talk to my 4wd shop to be sure. If the rear spun faster you would have a fishtail effect in icy conditions. So to help with that they make the front spin faster, just by a little
44,071 PostsLatest Activity: Aug 16, 2026
