wnjj
Jan 29, 2018Explorer II
mkirsch wrote:bobbolotune wrote:
The RAM manual talks about switching into 4WD but says nothing about switching out. It doesn't talk about binding and releasing binding when switching. As far as I can find, and I did look carefully.
They don't mention it because it's not common and something that most will never have to deal with.
Neutral and foot off the brake should be adequate to release any binding.
I respectfully disagree. The binding is between the front and rear axles and not just between the transmission and transfer case. Some movement with the wheels slightly turned is often needed. On flat ground that may require going back into gear to move some.
