Second_Chance
Aug 23, 2020Explorer II
Back to the 2,100 lbs. pin weight you are referring to. The GD Reflection 337RLS lists a pin weight of 2,090 on the web site. That is EMPTY! Our 2016 Reflection 337RLS (same advertised specs as the new ones) was ALWAYS over 3,000 lbs. on the pin loaded - every time we crossed the CAT scales. Never use advertised pin weights - use 23% of the fifth wheel's GVWR to estimate a loaded pin weight. In the case of the Reflection 337RLS (GVWR 13,995), that would be around 3,200 lbs. (which we only got up to once and off-loaded some things to get closer to 3,100 lbs.).
Rob
Rob
44,067 PostsLatest Activity: Jun 03, 2026
