renojack wrote:
Tire sticker says 2021. Ram Brochure says 2310. Grand Dedign spec says 2090.
There is a yellow sticker inside the drivers door, somewhere on the door jamb.... That will all you what the exact payload capacities..
** IF ** The Grand Design shows a DRY pin weight of 2100..... You will be overweight ... with only 300 # of padding, that is NOT enough to add the hitch weight and stuff in the camper- renojackExplorerTire sticker says 2021. Ram Brochure says 2310. Grand Dedign spec says 2090.
- TankcarExplorerHello! The truck door jam plate say?
- LwiddisExplorer IIDidn’t OP say 2500?
- rvshrinkerExplorer IIIwhat is the payload on your door jamb?
- LwiddisExplorer IIA dry pin weight of 2100? If so, you’ll be over your truck’s payload max when wet and loaded. Add a passenger or two....
44,054 PostsLatest Activity: Dec 22, 2025
