Bigfoot_affair
Mar 18, 2016Nomad II
ShinerBock wrote:Bigfoot affair wrote:FishOnOne wrote:
Yes the pre 2015 6.7 Powerstroke do have exhaust braking (your wrong), but is not as effective as the other brands.
ShinerBock wrote:
Wrong! The 2011-2014 Powerstrokes did not have an exhaust brake regardless if Ford wants to call it an exhaust brake "function". They had an engine brake(since it worked inside the engine) that manipulated the valves to force exhaust gases into the air intake stroke to starve the combustion process. There is a difference between an exhaust brake and engine brake, and what Ford had was NOT an exhaust brake which is a restriction in the exhaust outside the engine to cause back pressure which has greater stopping force than the engine braking that Ford used.
What?? Now I really know you don't have a clue. I am not a Ford guy and I know that this is not the case with the 2011-14 6.7 Scorpion. They used the vg's in the turbo just like Ram and GM does, it just wasn't effective and one of the reasons they updated the turbo on the 15's and up.
Really? I don't have a clue? So does this video mean Ford does not have a clue about their own engine as well?
Fords 6.7L exhaust brake "function"Bigfoot affair wrote:
Give it a rest already. Who cares (other than you) that the Ram needed a few more taps of the brake to slow down.
Apparently the OP since he mentions it in the very first post and everyone else that was talking about it before I even posted here so......
Cute video, using exhaust to snuff out the combustion process. Wouldn't you just shut fuel off the to cylinders? LOL! Obviously a video made to entertain people like you.
Inside look at the 6.7 Scorpion
I'll save you the trouble of reading the whole article, here is the paragraph that explains the reasons behind the upgraded turbo charger... You guessed it, better exhaust braking performance.
With the improvements to the turbocharger and exhaust, Ford is now able to increase engine braking. The previous generation had some but it was rather limited due to the concern of overspinning the turbocharger.
44,070 PostsLatest Activity: Sep 18, 2026
