- MiniAdventuresExplorer
BradW wrote:
MiniAdventures wrote:
My experience has been that the 12v option on the
frig does not work very well, anyway.
The Dometic in our Lance has worked great on 12V for 22 years except for the large draw on the battery. We had problem with the gas side. Could not keep the pilot lit over about 40 mph. I tried all the "fixes" back in the 90's; nothing fixed it. :)
Brad
Glad it worked for you. The 'drain' on the battery you mention was one we found out about the hard way. That, coupled with the fact that the cooling was nowhere near as good as with AC or propane for us, was why we stopped using it on DC. We did have some success with a 'filter' attached over the external exhaust panel when on propane, but I did not like the idea of running on propane at 70 mph. :E - BradWExplorer II
I've never seen the bed plug mounted in the front spacer board. I like that idea. I'm not sure if I will end up needing a spacer board or not. We have one currently on our 2006 F350; otherwise the camper would contact the truck taillights.
Thanks for posting,
Brad - NRALIFRExplorerBrad on my previous trucks that were all bought used, I didn’t even hesitate to take a hole saw to the bed and mount the plug where it was most convenient for me. For some reason though, I just couldn’t cut a hole in my brand new 2016 truck. I know Ford made some major changes to the Superduties in 2017, but hopefully this detail hasn’t changed.
On the front wall of the bed, there are a couple of holes with plastic plugs in them. I used the one on the driver side as a pass-through hole for the camper plug wires.
I also needed a 2.5” spacer at the front of the bed to keep my the camper from touching the truck taillights, and I was installing 4 awg wires to the truck batteries at the same time. That’s why I have the board at the front, and the two plugs mounted in a plastic box.
The two 12 volt wires are in the big 2-pin Pollak plug, and the marker lights, brake/turn signals, and backup lights are in the smaller 4-pin plug. I spliced those four wires into the 5th wheel plug at the rear of the bed.
:):) - jaycocreekExplorer IIThe extension will solve all your problems.The guy I bought TC from had Gall Boats and RV in Missoula make him one for his Dodge dually.Works great without having to be under the TC to plug in and I have a plug-in in the front fender well.
- Gary_MorencyExplorerThe cord I bought from Lance was 9ft long just hooked a 7 pin on the other end and plugged into the outlet at the bumper works great,no cutting into the wiring of a new truck.
- BradWExplorer IIYep, we never did install the larger 8 ga wire to the truck battery. So when we ran our frig on 12V on the highway, the camper battery would be pretty much dead if we drove over 8 hours.
- FreepExplorer
Brad
We have the same issue, which is why I bit the bullet and had the correct bed plug and proper wiring installed on our truck. Since then I always use DC when driving and gas or AC when stationary.
An added benefit is the battery charges faster now. - BradWExplorer II
Brad - MiniAdventuresExplorerMy experience has been that the 12v option on the
frig does not work very well, anyway. - BradWExplorer IIThe fridge in our new Lance is a 2-way frig, which I assume does not have 12V operation.
44,070 PostsLatest Activity: Sep 18, 2026
