Buzzcut1
Aug 29, 2018Nomad II
Dome wrote:
If you need an extra plugin for towing, the easy way is to buy a "Y" adaptor that plugs in to the rear bumper plugin. No wiring needed.
Lance uses a completely different wiring set up than your 7 pin connector on the hitch.
Brad I can't see the plug being in a different spot from previous year models with a steel bed. on both my 03 and 11 F350s the plug in is half way up the drivers side stake pocket bulge, about even with the drivers front bed tie down
