4x4ord
Dec 19, 2016Explorer III
Grit dog wrote:
And one can pick apart dynos as well. 2 dynos, different conditions, etc, etc,etc.
Either way, we all know there's more than a 4% loss from crank to pavement.
So either, it's a rigged test ( we can open the popcorn bar up on that one) or GM was/is conservative in their ratings and that Dmax is a powerhouse!
I take it you come up with the 4% drive loss by using the 880 lb ft mentioned in the video and the 910 lbft that GM rates the truck at. So if we agree 4% is impossible and assuming an unlikely driveline loss of only 12%, then either the new Duramax is making at least 1000 lbft of torque and GM has decided to be conservative on their numbers and rate the new engine at 910 lbft or the test is rigged.
I think there is a most likely third option: That the 880 lb ft of torque is not meant to represent the engine torque less driveline loss but rather it is the torque measured on the dyno rollers.
