lanerd
May 02, 2017Explorer II
A good way to check to see if fuse #32 is indeed disabling the odometer is to turn the key to ACC (where it's suppose to be when towing) and you'll notice that the digital odometer display will come on. Now, remove fuse #32 and the display should go out.
I'm not familiar with the RVI Brake 3, but is there any way that it keeps the odometer display active? Again with the ignition on ACC and fuse 32 removed.... connect the brake system and see if the display comes back on.
After looking a little at the RVI website, I see no way that this brake system can affect the digital display for the odometer.
So, I gotta ask. Can you tell us how you have come to this conclusion that miles are being added when being towed and the ignition on ACC and fuse 32 removed?
Ron
Ron
