Threebigfords
Aug 14, 2016Explorer
Cummins12V98 wrote:Threebigfords wrote:
You mean just like the Rams without the factory air bags?
I can't say I share your belief. Here's my F350 SRW with stock rear springs, just a taller rear block, no air bags. With a 4000lb camper in it putting it 2000lbs over its 9990 GVWR. Doesn't seem to be sagging to me.
So you did modify to make it sit like it does? How about a pic unloaded. Curious did you actually scale truck then truck with camper to determine 4K camper weight?
That was a 4" lift kit using new springs up front, STOCK springs with a taller block in the rear. This pic was taken the day I picked up the camper before any mods were made. After I added the 18ft Enclosed trailer at 8k lbs, on the Supertruss extension, I added Airbags and Stabil-loads.
This is how the truck sat Empty with no air in the bags the day I sold it last April. Truck scaled at 8100lbs empty and 12200 with the camper.
