- Trkdvr31ExplorerTalked to dealer today he said it was ok said that it was made the way because if the wheel was gonna fit perfectly under side fairing it would have to be cut.
- Cannondale61ExplorerThe wide spread axels sometimes look crooked after backing into parking spot. I thought mine was crooked but trailer was fine towing. Then when I looked at a rest area everything was fine. Now when I back in I pull forward then back into spot without any turning and tires and axels look fine,
- Trkdvr31ExplorerLol first unit. It was hard to tell about the sway it was real windy yesterday. I crawled underneath and measured the u bolt to the front of the leaf spring on both sides to see if it had slid forward on the right side but both were even. So maybe it just looks uneven because the slide skirt sits a little off in the wheel well area.
- Anmacc2ExplorerWhy do you think it's too far forward? Visual appearance could easily be deceiving. The alignment is important and should be precise. If the axle is crooked both wheals would be angled. Did it pull straight and true? Any sway? Scuffing? Did you travel far enough to show uneven tire wear? You said you just bought this unit today... Is it your first unit or do you have experience?
- 1492ModeratorMoved from Forum Technical Support
44,055 PostsLatest Activity: Dec 23, 2025
