strikeu wrote:
Grit dog wrote:
Well, what did you hear strikeu?
We all love rumors, conjecture and facts. Seems typically in that order as well. Lol.
the High pressure fuel pump fails a LOT in 2011-2017 6.7L powerstroke engines. there is a great many people trying to start a class action law suit on that issue. that particular fuel pump was made in Great Britain where the diesel is more "oily" than American specs. so when it runs with American standards diesel it disintegrates for lack of lubrication. it can destroy an entire engine to the tune of $10-15k.
it seems (no real data yet) that after 2017 there is a different fuel pump...so thats good if I am buying new, but not good for my 2012.
the next high fail item is / was the turbo. new turbo kits can be obtained but it seems the original turbo on the powerstrokes are some type of Rube Goldberg contraption that fails routinely. new turbo kits are ~$3k. this seems to be fixed in the 2015+ models,
bottom line is the 2017s are a bit too new to gather any real failure trends, but there are some significant data for the 2011-2017 6.7L powerstrokes. SO much that I am leaning back towards the RAM 3500.
strikeu wrote:
here is some of what I found. I closed the pages, so some simple searches will probably yield the same results
https://www.classaction.org/ford-diesel-fuel-pump-problem-lawsuits
https://www.claimspages.com/news/2018/11/28/classaction-lawsuit-proposed-against-ford-motor-company-for-6.7l-cp4-fuel-pump-failures/
https://www.littlepowershop.com/ford-6-7-powerstroke-diesel-common-issues-problems-and-fixes/
google powerstrokenation.com and look through the blogs. there is a TON of info on failures there. that page has a lot of pop-up ads so I have going there for long.
You said you had significant data. Could you post that. I looked at the articles you posted, and none have data. You can find a class action suit against about anything, including all vehicles.
I have a 2017 and the only issue I had was a cracked oil filter housing which was replaced under warranty. Had a 2012 before that and had a mirror go out after warranty and Ford picked up 1/2 the cost to replace.
