LIKE2BUILD wrote:
krsmitty wrote:
Yes, I am looking at the Chevy for future possibilities. We have a TT now, but still consider going back to a 5er. When I bought my 2017 I didn't do as thorough research as I should have. My 2017 (SB, SRW, 4x4) only has 2,300 lbs cargo capacity, which limits the size of a 5er. I believe the Chevy has around 5,500.
I like to play within the rules, but if you look closely at your Ram, the 10,000 GVWR is just a number so they can call it a 2500. On your door sticker you'll see FAWR is 5,750 and RAWR is 6,000. Combined you have "real" GVWR of 11,750. I know the weight police are preparing charges against me for say this, but your RAM only says 10K GVWR for the badge, not the real limit of the truck. What's interesting is my 2014 is even higher, I have a 6,000FAWR and 6,500RAWR :E
Your base rear axle weight is 2,900 and with a RAWR of 6,000 you actually have 3,100lbs of capacity and max trailer weight of 17,000lbs. If the 5er's you're considering exceed these values than that I'd say look into a dually. However, don't underestimate the capacity of your truck. If you like the current truck and find a 5er that matches the specs then I'd say keep the Ram. But, if you want to go bigger and need the dually capacity then by all means get the 3500HD to give you that safety factor.
Our previous 5er was 37' and about 12,500lbs fully loaded. The truck pulled that trailer just fine all through the Rockies, was very stable, I had plenty of power up the inclines, and the exhaust brake was AMAZING on the declines. I never measured the actual pin weight but calculating 25% I was about 3,100 lbs on the hitch. I never felt unsafe or over matched by the trailer. But again, if the specs of your (potential) trailers exceed the RAM then it's worth looking a higher capacity trucks.
KJ
Well a two part answer,
#1. KrSmitty, I assume that the GM 3500 is a DRW, up until 2020 or 2021 GM 3500 DRW’s topped out at 13,025 GVWR, Ford and Ram were 14,000#, that is as much as 975# more payload. If you want to step up, look for the new truck. Run searches on car Gurru, and auto trader, etc. Find the TV you want, not one that just pops up on a lot.
#2. Like2build, I ran that way going by GRWR, which was 6,084# on our 2001 Ram 2500, running that way I was 1,700# over GVWR. I worried about hungry lawyers, moved up to a
2016 Ram Laramie 3500 DRW HO, Aisin, 3.73’s 5,411# payload, 25,024# pulling capacity.
