2112 wrote:
Rocknita wrote:
*snip* OP said his son doesn’t tow or haul and most everyone is giving advice about using TH and full EB. *snip*
So do most people use T/H when not towing?
Thanks for all the feedback. It's good to know to not expect much more than 30k miles on his Firestones.
He's running 80psi on all 4 Firestones all the time. I suggested decreasing pressure to ~65psi to soften the ride but he said the manual says run them at 80psi. I haven't read the manual to know how it's worded. Where should he have his tire pressure unloaded?
Officially he's supposed to run 60 on the fronts and 80 on the rears. If he's not towing 60 all around would be about perfect - that's what I do during the off-season.
