KenS999's avatar
KenS999
2018 F-150 Adding 7 Way Plug For Towing
Hi,
I have a 2018 F-150 XL without the factory towing package. It does have a factory installed 4 pin towing connector. Would it be also factory wired for adding a 7 Way towing connector? If yes, where is the location and of harness or outlet. Was under the truck, dont really see any unused wiring harness or plug.
thanks,
Ken
  • Not a Ford guy but most manufactures have the pigtail wired in at the back of the truck. You can order the seven connector from Ford or get an after market one and just plug it in. To confirm this crawl under the back of the truck and look behind the center of the bumper. You are looking for a pigtail with a plug covering the end. It may be covered with tape to protect it.
    Don
