afidel
Dec 01, 2017Explorer II
So the 13,200 configuration is the long wheelbase 2x4 SuperCrew with the max towing package and the gen 2 ecoboost 3.5. It looks like the max payload for that configuration is 2,870 (if also equipped with HD package, but the max tow is for the max GCWR config so I assume it implies HD) so tongue weight shouldn't be a big deal except for the fact that the class IV hitch maxes out at 1,320 if they keep to the same rating formula they've used for the last few models. I've not seen a class v hitch for the F150 so you'd have to have a custom one made if you want to exceed the 1,320 tongue weight.
Then again at 9k gross weight you'd have to be really close to 15% to exceed 1,320 so just add some weight behind the axles to get it down a tad =)
