Gdetrailer
Dec 03, 2017Explorer III
Maury82 wrote:
During the two years that I have been lurking, I picked up tons of much needed information regarding the ins and out of RV maintenance, problem areas, camping, and other information relating to RVing, but there is one thing I learn not to do, and that is to listen to the "doom and gloom" and the end of the world scare tactics of towing a longer and heavier TT with anything that is not a 3/4 or a 1 ton.
While I do understand this thing with guys and big trucks, but when it comes to advising newbies and other seeking credible information and advice about picking out a TV, I was a bit appalled at how so many would try to scare a new RVer into purchasing a huge TV for trailers that were well within the capability of properly quipped modern 1/2 ton. Most of you guys are just plain bias against a capable 1/2 ton towing a certain weight and length TT, and I don't believe most have even towed a heavy trailer with a modern 1/2, yet are the first one trying to scare a newbie into a 3/4. The more I read, the more I was convinced that a lot of the "doom and gloom" crew probably haven't towed much of anything with a modern and capable 1/2 ton, and there is no way would I make such an important decision based on Zero person experiences and Zero proof that towing a longer and heavier TT well within weight and towing limits of a 1/2 ton is dangerous or unsafe.
Next year I'm purchasing a 2018 F-150 EB with the Max trailering package for my 37 ft/ 8,300 dry(9,800) max TT, and based on how bias so many are, while not providing actual personal experiences with towing such TT with a modern 1/2 ton, I'm going with the information that Ford is providing, and based on that information, the F-150 should be plenty capable in all weight/payload capacities with room to spare.
I am absolutely convinced that many of the "half ton" folks have NEVER experienced potentially BETTER TOWING via a BETTER MORE CAPABLE vehicle platform with excessively longer and heavier loads.
I HAVE experienced a border line tow vehicle/trailer combo, thought it was normal to have the TRAILER push the vehicle around.
That came to a halt once I bought a 3/4 ton.
There IS a difference in the handling department.
Half tons do have their place, they are capable of decent loads, however the squishy suspension and P tires does LIMIT them..
So, you could put LT tires on them, perhaps add custom built heavier springs, perhaps air bags but then you have the ride of a 3/4 ton that you DIDN'T want.
Think the F150 is cheaper?
Think again.
A F150 with Eco and all the payload packages can have a MSRP north of $60K and you may have a max of 2,200 lbs payload and the wrong combination you may only get 1,800 lbs payload..
You can get a F250 with 6.2 gas for a MSRP around $50K and get 2900 lbs to 3500 lbs payload depending on cab and bed length..
If you want turbo, buy it, but you will pay more and get LESS capacity than a F250.
Don't paint yourself into a corner by only considering a F150, do some REAL research, price a F150 and then a F250 and compare capacities between them, it can be an eye opener..
