JIMNLIN
Dec 03, 2017Explorer III
If you get the Heavy Duty payload package then it's possible you won't be white knuckling all the time.
If you just get the Max Trailer Tow in a Super Crew 145" WB then good luck.
The Max Trailer Tow Package does nothing to make the truck more stable. It's just a bunch of added options for trailering.
Excellent point.
Too many F150 owners simply bought into the max tow hype and didn't look into the max gvwr/rawr packages. They get a small 6800-7000 lb gvwr and small 3800 rawr/P tires crew cab with the 5.0 or 3.5 eb engine/8-10 speed tranny and then complain the truck seems overloaded or being pushed around or a squishy/squirrelly handling. Then lump all 1/2 ton trucks in their bad choice.
The OP has indicated he not looking at for those big 10k-12k TT's but something in the 25'/8k range.
If he sticks with a F150 I would look at the 7550-7850 lb gvwr with a 4550-4800 rawr packages. The F150HD 7850 gvwr and 4800 rawr comes oem with LT tires.
Choose the right F150 5.0/3.5 eb engine for a 8k 25' trailer and their won't be any white knuckle or tiring towing experiences.
Choose the wrong one and you too can make wild claims about a 1/2 ton can't do the lob.
