jaycocreek
Dec 05, 2017Explorer II
But on the other hand, if I had an Excursion, or a 250 Van, with appropriately the same weight and wheel base, it's isn't an issue.
Laughing...But that is the truth on this forum.
If people would just read they could find things out.I read on a 2015 F-150 to find out they had three different axles and three different frame specs,depending on the package you choose..Example is the 9.75 HD axle rated higher than the 8.8 and 9.75 standard.
To bad they just don't have two variants,a standard F-150 and a HD 150 with the HD having all the packages to tow or haul advertised towing and hauling weights...That sure would make it black and white for the dis-believers!
