jerem0621
Dec 05, 2017Explorer II
jaycocreek wrote:But on the other hand, if I had an Excursion, or a 250 Van, with appropriately the same weight and wheel base, it's isn't an issue.
Laughing...But that is the truth on this forum.
If people would just read they could find things out.I read on a 2015 F-150 to find out they had three different axles and three different frame specs,depending on the package you choose..Example is the 9.75 HD axle rated higher than the 8.8 and 9.75 standard.
To bad they just don't have two variants,a standard F-150 and a HD 150 with the HD having all the packages to tow or haul advertised towing and hauling weights...That sure would make it black and white for the dis-believers!
Boy ain’t that the truth! My dad told me that my F150 could pull his 7,800 lbs UVW Fiver with my F150...my f150 has a 6,400 lb tow rating. It’s got the smaller 8.8 rear axle. If I change to 3.73 the rating goes up to 6,800 lbs.
So, for me and my use, I’m going to be shooting for something around 4,500 ish dry. It will be about 5,500 loaded up for camping and my truck will handle it great. I have lots of experience towing RV’s and look forward to putting my truck to work again.
Just based on my experience, while my 7,700 GVWR Travel trailer pushed about 7,000 lbs loaded and it towed great with my F150 my personal limit is about 7,000 lbs for a Half Ton Truck.
I get the rating system and all that stuff, but for my truck, if I’m towing 8-9k I really want a F250.
Here is why, I had a Dually that I towed with the same trailer listed above. I took it to Disney and I75 was tore to pieces in South Georgia. There was about a 20 ish mile stretch where there was no hard shoulder..there were concrete barriers sitting on the lines. There was heavy traffic and no where to go.
Let me tell you, I have never been more comforted by a vehicle than sitting in that right lane with those dually’s back there and a properly set up hitch and balanced trailer.
Other than that, I hated my Dually, but it sure was stable. Mostly hated the trim package. It was an XL and the interior was very uncomfortable.
This is what a lot of new Half Ton owners do not get. A HD truck is COMFORTING not necessarily comfortable in all situations. Rarely it’s the trailer weight that gets a Half Ton it’s the payload. Try as you might to manage the tongue weight on a trailer. Sometimes you just can’t get it to 10-15%. I had a 3000 Pup with 475 lbs of tongue weight. I couldn’t do anything about it. And believe me I tried. Towed great though.
My Buddy BenK says that when Murphy strikes it is not the time to make sure you have equipment that can handle Mr. murphy’s Whims.
Thanks!
Jeremiah
