billtex's avatar
billtex
Explorer II
Apr 18, 2019
2019 Chevy LTZ Duramax CC Dually payload?
Hi All, time for a new ride.
Can anyone give me a good idea of scale weight of truck and/or available payload?
Thx, Bill
  • Thanks All.
    First thing i do is check the door/glovebox...but that doesn’t give you actual truck and axle weights. Only a trip to the scales will give you those numbers!
    Here’s another (crazy) question; 2 similar trucks one lists the “A” dimension (camper loading) as 43” the other as 62”!
    WTF?
    I thought GM always measured the “A” from the rear?!
  • gm weights calculator
    Use GM weight calculator. It figures std packages and all added options for the trucks axle weights and gvwr weights.
    The only way to find a trucks real payload is scaled axle weights. Then do the math.
    Example from the calculator; ....3500 DRW 2wd LTZ diesel crew cab long bed = 6476 RAWR payload...5816 gvwr payload.
  • 14k gvw, payload will be around 5500lbs. Guessing truck is about 8500.
