Marcela
Jun 07, 2019Explorer
TxGearhead wrote:
Thanks Marcela. I need to look at my jacks again to refresh my thoughts on the fender clearance issue. I question my thoughts about extending the jacks out by adding something between the camper and the jack. Not sure about bending forces on a longer bolt, assuming using square tubing. Also if I have wood backing issues like you, it may go downhill. I guess I could just bolt the tubing to the camper and then bolt the jack to the other side of tubing. It's getting a bit convoluted when I could just be very very carefull when loading.
I really didn't have wood backing issues, all the fasteners are just not used:). The brackets are plenty strong at the attachment point.
Your deal is as you move the brackets out you also move them forward when they are collapsed in, interfering with the doors. Mine are close as is, I really need to put a 1/4" piece of plywood at the front.
