4x4ord wrote:
^^^ Exactly so if the turbo was holding enough back pressure to hold the load back at 2000 rpm (which is impossible), the engine would have been generating 175 reverse HP. Now, if, the transmission downshifts from 3rd to 2nd, the rpm would increase from 2000 to 3000 rpm. So even if the back pressure remained unchanged (The only reason the back pressure would remain unchanged would be if the valves started floating otherwise the back pressure would increase dramatically because the engine would be trying to push 1.5 x as much air past the turbo) the reverse HP generated would go from 175 to 262 reverse HP. So if 175 reverse HP was holding back about right and now all of a sudden the engine is holding back 1.5 times as much the truck would quickly start over braking while the turbo adjusted to relieve back pressure.
(and because the increase in engine rpm would not only cause 1.5 x as much air to be compressed it would also be compressing that air to a higher value ( ie the back pressure would go up ) so the reverse HP would rise even more than 1.5x )
So based on the behavior of the truck, it is my opinion that the exhaust brake was not the only thing holding the truck back.
But it wasn't hold the truck back at 2,000 rpm and was gaining speed which is why it downshifted to a higher that not only allowed it to hold speed, but also slowed it down. After it slowed it down to desired speed then the turbo vanes probably actuated between 95-99% to keep it there.
Also, the IKE is not 7% all the way down. There are sections that are as low as 3%. Especially the section coming right out of the tunnel. It is steep when you first come out and the decreases the grade for a short distance.
