ShinerBock
Feb 02, 2020Explorer
ib516 wrote:FishOnOne wrote:
I think the real news is the Ford 7.3 gas performed almost as well in the up hill pull test compared to the Ram 3500 cummins and the Chevy 3500 Duramax pulling the same load. And the during the Ford pull they had to back off the throttle for a little bit so the time could have been less.
Here's the pull times in ascending order:
Duramax: 8:24
Cummins: 8:25
7.3L Godzilla: 8:42
Link
So much for the "you gotta get a diesel!" crowd. Save 10k and get a 7.3L Ford gasser haha. The times would be even closer if it wasn't a test at 11,000 ft of elevation where the non-turbo gasser is losing hp.
Yeah, but if they set the max speed of the test to 70 mph or even 65 mph then those times for the diesels would be a lot less. However, since they limit it to 60 mph mow, you are not going to make a more perfect run than a little over 8 minutes.
44,070 PostsLatest Activity: Jul 01, 2022
